972
Highlighted
Configuring port channel on nexus 1000V
I am new to nexus 1000V, the setup is as follows, UCS Chassis with 4 Full width blades connected to 2 FI 6248UP.
each FI has uplink to a n5k (no VPC).
is there any template for configuring the nexus 1000v? how to configure the port-channel?
thanks.
2 ACCEPTED SOLUTIONS
Highlighted
Re: Configuring port channel on nexus 1000V
We recommend to use mac pinning  ( " channel-group auto mode on mac-pinning ")  when N1KV is used on UCS blades.
Following doc provides good overview on best practices.
Best Practices in Deploying Cisco Nexus 1000V Series Switches on Cisco UCS B and C Series Cisco UCS Manager Servers
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9902/white_paper_c11-558242.html
Padma
Highlighted
Hello Shadow,
On UCS, N1k port-channels are always configured with mac-pinning.  You do not mention how many adapter cards are present on the blade.  For a basic setup where all adapters carry the same traffic you would have 4 vNICs.  2vNICs on adapter 1 connecting to A & B fabrics.  Repeat on adapter 2.  Do not configured fabric failover.  On the N1k, add all four vNIC to the same port-profile.  For more complex setups such as dedicated vNICs for vMotion, iSCSI, etc, you may want more vNIC or less.
The port-channel configuration on the fabric interconnects has no relationship to using N1k.  Since the N5k will not be doing vPC, the best configuration would be a two links from each FI to each N5k.  Example: FI-A would have a link to N5k-1 and another to N5k-2.
This document contains a sample configuration for N1k on UCS:
https://supportforums.cisco.com/docs/DOC-18222
Matthew
2 REPLIES 2
Highlighted
Padma
Highlighted
Hello Shadow,
Matthew
Content for Community-Ad
Cisco COVID-19 Survey
