Hi everybody:
I'm trying to know how you can configure a VACL with multiples actions in a nexus 5x00.
It's perfectly possible in Catalyst something like this:
ip access-list GLBP-IP
10 permit udp any 224.0.0.102/32 eq 3222
ip access-list ALL-IPs
10 permit ip any any
vlan access-map FHRP-FILTER 40
match ip address GLBP-IP
action drop
vlan access-map FHRP-FILTER 50
match ip address ALL-IPs
action forward
vlan filter FHRP-FILTER vlan-list 10-15
But I can't find how to do it in Nexus 5x000
Thank you in advance
Al
Hi Manuel:
I did it, but in the example there are not any examples with multiples actions.
It is clear how to configure VACL with simple action, but not with mutiple as in Catalyst.
Thank you for your replay
We tried configuring multiple action in our lab and it looks like it is not supported on the N5K. We get the error below.
