Hi All,
Is it possible to connect a chassis with the 2208 IO modules to a UCS system with 6120 Fabric interconnects? if its possible, would we need to upgrade the firmware to UCSM 2.x ?
Kassim
Solved! Go to Solution.
Hello Kassim,
Yes, they are compatible.
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10276/data_sheet_c78-675243.html
And, yes, we need 2.0.x code on FI for 2208 IO module.
http://www.cisco.com/en/US/docs/unified_computing/ucs/hw/chassis/install/FRU.html#wp1337128
Padma
Hello Kassim,
Padma
Hi Padma,
Thanks for the information & it answers my question.
Kassim
