Highlighted
Beginner
Connecting UCS 6248 FI to N5K-C5548UP
hi,
How do i connect UCS 6248 Fabric Interconnect to N5K-C5548UP? do i need to use FCoE or vPC as i will have multiple SAN connected (using FC) on FI.
Please suggest best possible solution where i have minimul cabling hedache & can optimise physicl ports on N5K.
Mahesh
4 REPLIES 4
Highlighted
Enthusiast
Hi Mahesh,
Are you looking to use N5K uplink as a ethernet uplink or a FCoE uplink or both?
./Abhinav
Highlighted
hi Abhinav,
Can i configure vPC using FCoE as uplink? If yes i will use FCoE only
Also suggest if you have any better solution
Mahesh
Highlighted
Hi Mahesh,
vPC for FCoE uplink and / or unified uplinks is not supported at this time.
vPC only for pure ethernet uplinks still works the same way.
./Abhinav
Highlighted
This has been double posted.  Please remove one of these posts.
https://supportforums.cisco.com/message/3961765
Robert
Content for Community-Ad
