11-13-2012 09:14 AM - edited 03-01-2019 10:43 AM
I'd like to know what models of nexus 2000 fabric extenders can i use if i want to connect them to a pair of fabric interconnects 6248UP in a FEX deployment, so i can move service profiles between blade and rack servers.
Thanks for your answers.
Christian
Solved! Go to Solution.
11-13-2012 09:18 AM
Christian,
Have a look at this guide. It should answer all your questions:
Robert
11-13-2012 09:38 AM
Just to add, in the next release (2.1) coming out tentatively this month, we will be adding support for Single Wire Management (SWM) where both data and Management can utilize the same wire between the Rack servers and 2232 FEX's. This does require the 2nd Gen Cisco Virtual Interface Card (UCSC-PCIE-CSC-02) adapter as well which will be released along with UCS version 2.1. Existing adaptors will continue to utilize the two wire integration model documented in the guide above.
Robert
11-13-2012 09:18 AM
Christian,
Robert
11-13-2012 09:38 AM
Robert
11-15-2012 03:39 PM
Thanks Robert, this is the document i needed.
