Continuous Beep sound on UCS c220
Udupikrishna091
Hi Guys,
We just got a new UCS c220 server, we were deploying Esxi on it and all of a sudden it started alarming a beep sound and it is continuous, there are no logs generated either CIMC nor the led indications, what might be the possible reason, an inputs would be helpful, thnx in advance
Krishna
Daniel Laden
Level 4
Level 4
Udupi,
What CIMC and BIOS are on the system?  Were these updated since being received?  What is the beep pattern you are hearing?  What array controller is present in this C220.
Use the Host Upgrade Utility to upgrade to the latest firmware and bios for all components then run the following:
SSH to the CIMC IP address
scope chassis
power off <- THIS WILL POWER OFF THE SERVER so they need to make sure they have prepared for this.
scope firmware
update-all
Thank You,
Dan Laden
Cisco PDI Data Center
Want to know more about how PDI can assist you?
http://www.youtube.com/watch?v=4BebSCuxcQU&list=PL88EB353557455BD7
http://www.cisco.com/go/pdihelpdesk
Udupi,
As Dan stated, it might be an issue with your RAID. In the past, I have experienced similar beeping when there was an issue with the RAID group. Except for the LSI controller, I'm not aware of any other componentt that would continuously beep on the server during operation
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/sw/raid/configuration/guide/MegaRAID.html#wp1105151
Table 5-3 gives a translation between the beep intervals and potential issues.
If you can reboot and interogate the LSI OptionROM during POST, you may find what it is complaining about
Table 5-3     Summary of LSI MegaRAID Card Beep Codes
Beep Code
LSI Firmware State
Cause (Depending on RAID Level)
3 seconds on, 1 second off
SPEAKER_OFFLINE_ENTRY
RAID 0: One or more drives offline.
RAID 1: Two drives offline.
RAID 5: Two or more drives offline.
RAID 6: More than two drives offline.
1 second on, 1 second off
SPEAKER_DEGRADED_ENTRY
RAID 1: A mirrored drive failed.
RAID 5: One drive failed.
RAID 6: One or two drives failed.
1 second on, 3 seconds off
SPEAKER_HOTSPARE_ENTRY
A hot spare drive has completed the rebuild process and has been brought into the array.
Hi Dan,
Thnx for your inputs, below are the details on the box
CIMC Firmware - 1.4(6c), bios - C220M3.1.4.6a.0, we are using LSI megaraid, the thing is that the CIMC console as well it is not popping up any kind of error, everything is shown as good status
The beep is on for some 2 to 3 seconds and off for another 2 secs
Krishna
Curious. Was the software array controller enabled previously and a raid 5 built there?  Did the megaraid controller see this array?
I ran into a case today with the above scenario.  We updated to the latest firmware, we still had a 1 second on, 1 second off beep. All systems showed normal.  Array showed optimal.  Deleted and rebuild array and beep was gone.
You will want to protect anything on the array before deleteing the array.
Thank You,
Dan Laden
