Beginner
Decom Fabric Interconnects
We just replaced our first Fabric Interconnects with new ones, and need to get rid of our old FIs.  I know that all the service profile, configuration, etc. is stored on local hard disks on the FIs.  I plan on plugging them in one last time for an "erase configuration" command to delete the config.  Is there anything else people usually do to decom FIs?  If they were servers, we would degaus the hard disks.  Does anyone do anything that extreme?  Thanks!
4 REPLIES 4
Re: Decom Fabric Interconnects
Without some sort of dplug access to get to root level, there's not a lot you can do unless you want to erase config a couple of times, then upload a bunch of firmware bundles, although those will go to /bootflash, and there are other partitions that contain configs.  Those use flash/SSDs.
Kirk...
Beginner
Thanks, Kirk, I appreciate the reply.  I will keep this in mind as I work on this... I'm just not sure I will be able to get these on the network again, but I will see what I can figure out.
Beginner
I have used the following in our lab, appears to delete the entire directory structure.
Reaload switch then break with Ctrl + L
From Loader
loader> cmdline recoverymode=1
loader> cmdline init_system
Mark
Beginner
Thanks Mark for the reply.  I'll have to give that a shot and see how it goes.
Content for Community-Ad
August's Community Spotlight Awards
