09-11-2012 12:06 AM - edited 03-01-2019 10:36 AM
I'm upgrading my UCS to version 2.0.3c, and everything is working fine.
But when I upgraded the first FI, I got this Major Fault:
I don't dare to upgrade the second FI, before I fix this error.
I have seen that this certificate has to do with secure connection between Client Browser and UCSM.
I haven't made any certificate when the UCS was set up (because there where some consultant that sat up the solution).
What to I need to do?
/Stig Sand
Solved! Go to Solution.
09-11-2012 12:28 AM
Since you haven't done anything to the cert since installation, all you need to do is regenerate the default key ring.
Refer to this document, under "Regenerating the Default Keyring":
BR,
Glenn B
09-11-2012 12:28 AM
BR,
Glenn B
09-11-2012 12:33 AM
Thanks for quick response
So all I have to do is ?:
Step 1 UCS-A# scope security
Step 2 UCS-A /security # scope keyring default
Step 3 UCS-A /security/keyring # set regenerate yes
Step 4 UCS-A /security/keyring # commit-buffer
This will not create any issues?
09-11-2012 12:34 AM
That would be correct
09-11-2012 12:36 AM - last edited on 03-04-2020 04:59 PM by Gagandeep Kaur
Then I will try it.
I only need to do this once? Not on both FI?
09-11-2012 12:41 AM
You only need to do this on the active FI, not both, no.
09-11-2012 12:48 AM
Thanks Glenn
It did the trick
03-14-2013 04:21 PM
I followed the steps. But the fault was still there. I had to acknowledge the fault to make it go away. Is there a way to verify the keyring certificate is actually good?
03-14-2013 04:50 PM
To answer my own question, refer to this blog post:
http://www.vstrong.info/2012/12/05/how-to-regenerate-expired-ucs-manager-certificate/
I was able to verify the cert is valid.
08-04-2016 01:56 PM
Thanks for the quick fix!! works great
09-27-2015 03:29 AM
Thanks Glenn. It worked..!!
