Community Helping Community
1777
Beginner
Dell TL4000 Tape Library on Cisco UCS 6120
We have Cisco UCS 5108 with 2 Fabric Interconnect 6120XP. We are running VMware on my Cisco Blades. I need connect my Dell TL 4000 LTO3 tape library to this Cisco UCS so that I can configure one virtual machine with EMC Networker software to take backups of virtual machine data. When I connect the tape library to Cisco UCS, it does not recoginize it as Tape drive.
Kindly suggest how to configure the same.
Everyone's tags (5)
1 ACCEPTED SOLUTION
Enthusiast
Amit,
We do not support any direct attach FC tape library to the FI currently.
It can only be a FC switch or an end FC storage.
./Abhinav
4 REPLIES 4
Enthusiast
Hi Amit,
Quick question, are you connecting this tape library directly to the FI?
./Abhinav
Beginner
Yes I am connecting the Tape Library directly to Fabric Interconnect on 4Gbps FC port.
Enthusiast
Amit,
./Abhinav
If the Tape Library is connected through a switch - is it supported in that case?
Ed
Content for Community-Ad
FusionCharts will render here
