02-11-2019 01:33 AM
Hi Team,
Can i mix different Fabric Interconnect Models with the same UCS Chassis. For Example : 1x6248 and 1x6332 instead of 2x6248 or 2x6332?
Solved! Go to Solution.
02-11-2019 01:38 AM
Hi Youssef,
Fabric Interconencts of different models is only supported during an upgrade process from say 2x6248 to 2x6332
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
02-11-2019 01:38 AM
Hi Youssef,
I hope this helps
02-11-2019 01:40 AM
Thank you Chris,
Really appreciate!
