Currently, I have blades B200M3 with 16GB (Qty: 12)==192GB total – populated with factory default setting.
Hello UCS community...
Does any one come across or tested DIMM/Rank sparing option? Hope someone will answer above question...
Hi Hetal ,
After some investigation about this feature, I want to inform you that the memory sparing is not supported in UCS blade servers.
Recommended to use memory mirroring instead.
David
Hi David,
I want to ask that, Is Online Spare Memory support in UCS M460 M4?
