Highlighted
Beginner
DIMM/Rank Sparing
Currently, I have blades B200M3 with 16GB (Qty: 12)==192GB total – populated with factory default setting.
  • •1. DIMM Sparing:-- What is usable memory and how many module will be used as spare?
  • •2. Rank Sparing:- What is usable memory and how many module will be used as spare?
  • •3. When I choose DIMM/Rank Sparing and applied it to service profile, OS Windows 2012 is still reporting full capacity—192GB. Why DIMM and Rank sparing is not reserving any spare RAM?
  • Thanks
  • Hetal Soni
3 REPLIES 3
Highlighted
Beginner
Hello UCS community...
Does any one come across or tested DIMM/Rank sparing option?  Hope someone will answer above question...
Highlighted
Hi Hetal ,
After some investigation about this feature, I want to inform you that the memory sparing is not supported in UCS blade servers.
Recommended to use memory mirroring instead.
David
Highlighted
Hi David,
I want to ask that, Is Online Spare Memory support in UCS M460 M4?
Content for Community-Ad
