Empty Storage TAB in CIMC 1.4(3k) with LSI 1064e
PatrickHauer
Hello Everyone,
CIMC of C200 M2 Server does not show LSI1064 Device and attached HardDrives.
Is this a Bug or a Feature?
With LSI MegaRaid PCIe Controller it is working.
Thx for help
abbharga
Level 4
Level 4
Hi Patrick,
As per design the storage tab is supposed to show information when you use PCI storage controller. The 1064E controller is not a LSI controller but a mezz card.
Thanks!
./Abhinav
6 Replies 6
abbharga
Level 4
Level 4
Hi Patrick,
Thanks!
./Abhinav
Sorry to respond to a closed out thread, but if you are using the LSI 1064e mezz card, how can you view disk information using CIMC?
Nick,
If you have that controller, you may not use CIMC for that, but you have the option to:
1-Reboot the server and get into the RAID controller to get the information (disruptive as it involves the servers coming down)
2- Or you may download MSM (MegaRAID Storage Manager) from LSI's website and monitor with this GUI only for the controller and that does not require a reboot at all, you may go to:
http://www.lsi.com/products/storagecomponents/Pages/LSISAS1064E.aspx > Support and Downloads and see what MSM you may download
I hope that helps.
-Kenny
sorry but what's the difference between a mezz card and a controller? If I am using the 1064e, how can I check my physical drive on the cimc? Thanks
Mezz card is the VIC, typically and the storage controller is going to be the RAID card.
You can likely boot up the server and press the CTRL + key stroke combination you see when you boot the server.
I have seen this before. Try a different Java version and the vMedia tab should be there.
Try something like Java 6 or another Java 7, like 7u45
