Enable CDP on UCSC series servers
tchoang
I would like to enable CDP on UCSC servers so that it will show up in 'show cdp neighbor' in the TOR switch.
By default, I don't see CDP is enabled.
Would you let me know how to enable CDP on the UCSC server
Thanh
Kirk J
CDP is a protocol normally provided by a switch/router or switch type device (i.e. ESXi host with vswitch).
A compute device not running anything like ESXi with vswitch or N1k, is not going to send out CDP.
What OS do you have installed?
Kirk...
Hi Kirk
  Thanks for your respond.
   I have a mix of both.  I have ESXi 6.0 installed on some servers and Redhat Openstack on other servers.  I want to have APIC-EM to discover all of the devices in my lab network.  Thus, the need of enable CDP on UCS server
THanh
Greetings.
To enable CDP in ESXi, see https://kb.vmware.com/selfservice/search.do?cmd=displayKC&docType=kc&docTypeID=DT_KB_1_1&externalId=1003885
To enable LLDP in ESXi, see https://pubs.vmware.com/vsphere-51/index.jsp?topic=%2Fcom.vmware.vsphere.networking.doc%2FGUID-FA7A38BA-002B-4AF0-B50A-9F371B2AF06A.html
For RedHat you may want to consider enabling LLDP, which I 'think' APIC-EM can also use.
Kirk...
Thank you Kirk for the information.  Will check them out.
Thanh
