09-22-2016 06:03 PM - edited 03-01-2019 12:53 PM
Customer has BE7K servers (UCS C-240 M4) it came pre-installed with ESXi 5.5 and 4 virtual drives, each virtual drive is configured with RAID 5. Now we need to install an UC application which requires RAID 10. We are not using one of the Datastore for any guest OS so our plan is to delete that DS and respective Virtual Drive, break that RAID and rebuild that to RAID 10 here is the challenge how can we identify which Datastore mapped to what Virtual Drive? My understanding is ESXi does not map 1-1 (i.e VD0=DS1). If any one can shed some light on to identify this would be really appreciated.
Thanks..!
Solved! Go to Solution.
09-22-2016 06:27 PM
Greetings.
Take a look at https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1014953
esxcli storage core path list
esxcli storage filesystem list
esxcli storage vmfs extent list
esxcfg-scsidevs -m
esxcfg-scsidevs -l
These should provide enough info to confirm which datastore is mapped to the VD in question.
Kirk...
09-23-2016 08:05 AM
Hopefully this is a little more concise:
Take output of
~ # esxcfg-scsidevs -m
naa.678da6e715d760101f0aa4a61d982f63:1 /vmfs/devices/disks/naa.678da6e715d760101f0aa4a61d982f63:1 5777f3b3-7bd4c97a-4ba0-a0369f9400b4 0 datastore4
Then match this with the output of esxcli storage core path list:
unknown.vmhba1-unknown.2:2-naa.678da6e715d760101f0aa4a61d982f63
UID: unknown.vmhba1-unknown.2:2-naa.678da6e715d760101f0aa4a61d982f63
Runtime Name: vmhba1:C2:T2:L0
Device: naa.678da6e715d760101f0aa4a61d982f63
Device Display Name: Local Cisco Disk (naa.678da6e715d760101f0aa4a61d982f63)
Adapter: vmhba1
Channel: 2
Target: 2
LUN: 0
... snip
This should correspond with your 3rd VD, since the target and VD#s start with 0.
Confirmed this in the lab: See below
VD0 (1st virtual drive created) does correspond with T0...and VD3 corresponds to T3.
These numbers of course are unique to each hba/controller so you want to make sure the vhba # and controller # (vmhba1 and C2 in my example) are from the same device when matching these up.
Kirk...
09-22-2016 06:27 PM
Greetings.
esxcfg-scsidevs -m
esxcfg-scsidevs -l
Kirk...
09-22-2016 06:43 PM
09-23-2016 08:05 AM
Take output of
Adapter: vmhba1
Channel: 2
Target: 2
LUN: 0
... snip
Kirk...
09-23-2016 08:05 AM
Kirk,
Thanks. Please can you verify and let me know that would be great.
09-28-2016 01:44 PM
Making sure you saw the lab info I updated in above post...
Kirk...
09-28-2016 03:40 PM
Thank you so much for taking time to do this in your lab. I really appreciate your help.
09-26-2016 08:55 AM
Did you had a chance to verify this? Please let me know.
Thanks.
