This a little bit more complicated than just a standard N5K due to the additional UCSM layer.
You can create backups, which for 'logical' is just an XML file that contains the various pools, service profiles
- Logical configuration—An XML file that includes all logical configuration settings such as service profiles, VLANs, VSANs, pools, and policies. You can use the file generated from this backup to import these configuration settings to the original fabric interconnect or to a different fabric interconnect. You cannot use this file for a system restore.
You can connect to the nxos layer on the FIs and do a show run,,, but the nxos layer on FIs is not something you can general enter the saved config commands back into.
Kirk...
