F0997 raid battery
rbadilla
Hi all:
Recently was checking an UCS 240m3 remotely via ssh to the CIMC.
Found these entries on the Fault History and want to know If its time to change the BBU?
04/11/2019 23:01:34 raid-battery cleared
04/11/2019 22:59 F0997 raid battery
Or is normal that BBU reports F0097 after whole server reboot and then raid-battery cleared is asserted.
Thanks for any input!
Kirk J
You will normally have a number of self tests that get checked, and then alert clears that are asserted.
Also, you may see some when the raid controller runs BBU/Supercap learning cycle where it tests to make sure it is functional (every 28 days or so I believe)
Kirk...
