11-09-2011 12:46 AM - edited 03-01-2019 10:08 AM
I have two fabric interconnect 6120xp in cluster on one i find the ip in running config and on the partner i dont. It might be due to this i dont get the ipaddress of the fabric interconnect (shows as 0.0.0.0) on my san switch when querying fcns database. Any help is appreciated.
lhr02-wxp00-fic01-B(nxos)# sh run |inc ip
ip host lhr02-wxp00-fic01-B 10.255.96.78
ip address 10.255.96.78/24
lhr02-wxp00-fic01-A(nxos)# sh run |inc ip
role name server-equipment
lhr02-wxif-san02# show fcns database npv
VSAN 20:
NPV NODE-NAME NPV IP_ADDR NPV IF CORE SWITCH WWN CORE IF
20:14:54:7f:ee:04:c8:01 10.255.96.78 fc2/4 20:00:54:7f:ee:07:6e:80 fc1/6
20:14:54:7f:ee:04:c8:01 10.255.96.78 fc2/2 20:00:54:7f:ee:07:6e:80 fc1/5
lhr02-wxif-san01# show fcns database npv
VSAN 10:
20:0a:54:7f:ee:03:ee:c1 0.0.0.0 fc2/1 20:00:54:7f:ee:17:eb:80 fc1/3
20:0a:54:7f:ee:03:ee:c1 0.0.0.0 fc2/3 20:00:54:7f:ee:17:eb:80 fc1/4
11-17-2011 07:28 PM
On the FI with the 0.0.0.0 ipaddress run the sho npv inter info | inc IP.
Next go into UCSM and select the equipment tab.Then pick the FI in question. On the right select General tab and then Access.
What is the ipaddress? Does it also show 0.0.0.0 here as well?
If it does, try changing it to the address you wanted and check it again.
If that does not work then you can try to erase the config on that FI and reconfiguring it from the begining.
Verify they it joins the cluster and HA is ready and the ipaddress is available.
11-17-2011 07:55 PM
lhr02-wxp00-fic01-A(nxos)# show npv internal info |inc IP
Switch Mgmt IP Address: null
On the UCSM i am able to see the IP , i cant erase the config as these are already in production , any other alternative to fix this
