Failed Drive on chassis
darrell.lewis
Beginner
Beginner
I have a light indicating a failed drive on the UCS. I can't seem to find the same indication on the UCS Manager. Where should one look to find a drive failure? I've looked through and everything appears normal.
1 REPLY 1
stechamb
Beginner
Beginner
If you navigate through Equipment -> Chassis -> Chassis n -> Servers -> Server n
There should be a fault in there if there's a fault with the blade...
