02-27-2014 12:47 PM - edited 03-01-2019 11:33 AM
We've had our UCS B Series chassis up for almost 2 years now and it's time to update the firmware from 2.0(3b) to the latest. This is uncharted territory so I wanted to get some feedback from those who have already updated their firmware. Our servers are B230 M2s and B200 M3s all deployed with the same Service Profile Template. We have 2 fabric interconnects. All the servers are part of a VMware cluster.
I've been using this Cisco document as a reference to prepare for the update: http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/upgrading/from2-0/to2-1/b_UpgradingCiscoUCSFrom2-0To2-1.html
What I'm unclear on is the steps (which is pretty much all there is) and I'm hoping someone can confirm that I've got this in the right order.
And those are the steps as I understand them. I'd really appreciate any corrections or additions. Thanks for the help.
Solved! Go to Solution.
02-27-2014 01:32 PM
You can go directly from 2.0 to 2.2 see
Upgrading Cisco UCS from Release 2.0 to Release 2.2
Steps 1 and 2 have to be done
The remaining steps describe actually the manual upgrade procedure.
However, there is a much easier way; autoinstall infrastructure resp. servers (based on host firmware packages).
3) As a first step, upgrade UCS Manager to eg. 2.2.1c, and then you have the menu options for autoinstall.
4) Autoinstall infrastructure
5) Autoinstall servers
see eg. Cisco UCS B-Series GUI Firmware Management Guide, Release 2.2
02-27-2014 01:32 PM
02-28-2014 12:21 PM
Thanks wdey. I think I understand. Upgrading UCS Manager to 2.2.1c will give me the autoinstall options for everything that follows (infrastructure, adapters, CIMCs, IOMs, servers)?
Under this autoinstall scenario do I need to update the fabric interconnects one at a time or does the autoinstall update and failover as necessary?
Thanks for that last link. It was very useful. I see now the breakdown of what the infrastructure software bundle includes and the server software bundle contents. Are both of these uploaded to the FIs in my step 1 step 2 above?
02-28-2014 01:08 PM
Yes ! Infrastructure = UCSM (which you upgrade manually first), IOM, and FI
Server is actually done with Host Firmware Package, therefore create one eg. name it "HFP", and include it in your service profiles. Then with Autoinstall server, you refer to this "HFP", which will then be updated to e.g. 2.2.1c, and CIMC, BIOS, Adaptor,.... is updated (which requires a server reboot); therefore check, that you have a maintenance policy with ACK in place !!
This is all done automatically ! starting with IOM and then slave FI; then the upgrade stops and waits for a ACK, after which the master FI is done; before the ACK you should check, that all your uplinks.... are ok
Yes
PS. During the upgrade, you might see tons of error messages, which you can very likely forget, and clear when the upgrade is done
02-28-2014 02:05 PM
Thanks wdey. The UCSM update and infrastructure firmware updates make sense now.
I'm still a little unsure of the server updates. Right now we just have one HFP called B230_m2. We use it for both models of servers in our chassis.
Based on the screenshot below, it looks like this HFP is linked to the service profile template
So, would I create a new Host Firmware Package and go into the service profile template and choose it from the dropdown menu shown above? Does this replace the HFP for all servers at once?
03-01-2014 12:33 AM
Perfect ! you already have a Host Firmware Package. No need to create a new one.
During the autoinstall server, you can select your existing HFP "B230_m2", which will then be updated according the version you specifiy for the migration, e.g. 2.2.1c.
You also have a HFP "default" which is empty; this can also be updated to the release you go for.
See also new features like "Firmware Automatic Synchronization Server policy"
You can use the
Firmware Auto Sync Serverpolicy in Cisco UCS Manager to determine when and how
firmware versions on recently discovered servers must be upgraded. With this policy, you can upgrade the
firmware versions of recently discovered unassociated servers to match the firmware version defined in the
default host firmware pack. In addition, you can determine if the firmware upgrade process should run
immediately after the server is discovered or run at a later time.
