07-21-2015 04:10 PM - edited 03-01-2019 12:17 PM
Hello Everyone
I am getting an error stating our flexflash is unhealthy after firmware upgrade. Says it is running old firmware. I did not even know we had flexflash on our systems and do not see away to upgrade the firmware. I read that you are supposed to see this in the storage tab but do not see this . How do i resolve this error?
Solved! Go to Solution.
07-21-2015 06:00 PM
I ran into the same thing after upgrading to 2.2(5a) from 2.2(3e).
Everything went fine but that. It was minor.
The only thing I could do to fix it was, decom the blade, pull it out, put it back in, and re-ack the server. Then it went away.
(We use the FlexFlash and it did not cause any problems before or after the warning). You can try resetting the FlexFlash controller, but I don't think that'll work for this particular minor warning.
07-21-2015 06:00 PM
07-21-2015 07:20 PM
Also having this problem, going to try decom, pull, put back in, re-ack in the morning.
I did a decom and then a re-ack and this evening and that by itself didn't resolve the issue.
07-21-2015 09:40 PM
Yep, tried that as well (first). The only way was to pull it out completely and put it back in - very weird.
07-22-2015 05:26 AM
Confirmed, reseating this morning resolved my issue. Thanks!
06-10-2018 08:25 AM - edited 06-10-2018 09:32 AM
Decommissioning and reseating the blade resolved my issue as well.
07-22-2015 10:07 AM
Jason,
are you using flexflash for storage pupose? from your description it doesnt seem so.
please reset the FlexFlash Controller to clear the message.
1. Log into the UCSM
2. Select the Server in the Navigation Pane
3. Select Storage Tab in the viewing pane
4. Then select Controller
5. In the viewing pane, you may see a reset FlexFlash controller link.
6. Reset the FlexFlash controller
-Saurabh
07-23-2015 12:21 PM
That did it!
Thanks, was really confusing could I knew we were not using flex cache. A lot docs say to go to the storage tab and look there but as you said it is storage tab on the actual server. I guess the controller is there even if you do not have flex cache cards.
07-23-2015 12:23 PM
Jason,
thank you.
*Please do not forget to rate all usefull posts
07-23-2015 01:23 PM
Saurabh,
Can we safely do this if we are using SD cards? You mentioned in your post that you didn't think Jason was using FlexFlash so I'm not sure if that played into your recommendation to reset the FlexFlash controller.
As John said, I would be scared to try it as I wouldn't want to wipe ESXi off my SD cards.
07-23-2015 03:54 PM
Yes I do not have any flex cache so resetting flex controller was not an issue. I would assume if you are using the flex cache for OS or data that a good possibility it was cause some issue.
07-23-2015 01:16 PM
Ah, nice. I didn't want to try that as I didn't want to wipe ESXi off my SD card.
10-11-2015 07:36 AM
Just a step-by-step.
Cisco UCS 5108 AC2
B200 M4 blades
Boot from SAN
Note: just updated infra and server FW to 2.2 (5b)
We don't have flash cards but the controller is there.
*** Pay attention to any pop-up warnings.
*** Expand FlexFlash Cards to verify if you do or don't have any cards installed and make sure you are aware of how each server/blade boots if it does have cards.
In our case this was non-disruptive since we boot from SAN. Understand your case first.
Take a look at "Configure and Use Cisco FlexFlash Secure Digital Cards on Cisco UCS Servers" white paper.
Equipment tab, Chassis, Chassis x, Servers, Server x, Inventory, Storage, scroll down to FlexFlash Controller x, *** Reset FlexFlash Controller
04-19-2016 01:13 PM
The reset of the FlexFlash controller addressed my issue.
04-28-2016 07:24 PM
CSCut10525 - FlexFlash FFCH_ERROR_OLD_FIRMWARE_RUNNING error on B200 M4
