12909
Highlighted
Re: CSCut10525 - FlexFlash FFCH
Yes the re seating resolved the issue. Complete power cycle and re acknowledgment resolved the issue.
Beginner
This did trick with me.
This did trick with me.  thanks!
Beginner
This worked for me too, with
This worked for me too, with the slight exception that you have to click on the Blade, the Inventory, then the storage tab.
Beginner
Thanks, This resolved my
Thanks, This resolved my error as well.
Helpful post.
Beginner
Beginner
Re: Flexflash Controller is in a unhealthy state after firmware upgrade
I just fixed it by resetting the flex flash controller on the server inventory options
Beginner
Same goes for me, we resolved this issue several times by resetting the flex flash controller.
You just have to be patient: after the reset it takes some minutes after the error disappears.
Beginner
Having similar issue with (UCSB-B200-M4) FlexFlash error below: will resetting wipe out the contents of SDCARD? Will the ESXi Host bootup fine after reset?
Error Invalid Size
Beginner
Reseting the Controller is disruptive as the server looses the connection to the SD cards.
But it will not erase the content of the cards. If you want to delete the cards you have to choose "Format SD Cards".
Beginner
No, the reset Flex Flash controller action will not wipe the SD, but it will lose connectivity very shortly to the SD cards so make sure to turn off the server before performing this. OS will still be installed on the SD cards after the reset
Beginner
Thanks for the responses! Guess I have one bad SD card, reset only yielded true issue.
Error Invalid Size typically indicates a problem with the SD card themselves.
If you were getting a "flexflash controller unresponsive" then a reset would likely resolve this.
I have also seen this message when the two SD cards being used are not identical. (Different size, etc). The platform requires that the two cards be identical.
Beginner
We have 2 SD cards setup as RAID1, but that server is only showing 1 now, and it's marked as an "Unpaired primary" that will not boot ESXi? Is having 2 cards pointless for HA/redundancy?
Having two cards is necessary for redundancy, yes. It sounds like the OS may have been corrupted or lost after the upgrade. If the card would have failed during operation, the OS would remain on a single card.
When you attempt to boot the server, do you get an error? Does ESXi display anything or do you get "no boot device found"?
The most effective use of time would to be just re-install ESXi and re-configure the management settings. If you would like to try and recover, I would boot an ESXi Installer ISO and choose to "upgrade" and see if the boot partition is still available. If not, it may have been lost/corrupted during an upgrade/when the card failed.
Content for Community-Ad
August's Community Spotlight Awards
