07-21-2015 04:10 PM - edited 03-01-2019 12:17 PM
Hello Everyone
I am getting an error stating our flexflash is unhealthy after firmware upgrade. Says it is running old firmware. I did not even know we had flexflash on our systems and do not see away to upgrade the firmware. I read that you are supposed to see this in the storage tab but do not see this . How do i resolve this error?
Solved! Go to Solution.
08-06-2018 11:56 AM
We have 2 SD cards setup as RAID1, but that server is only showing 1 now, and it's marked as an "Unpaired primary" that will not boot ESXi? Is having 2 cards pointless for HA/redundancy?
08-06-2018 12:00 PM
Having two cards is necessary for redundancy, yes. It sounds like the OS may have been corrupted or lost after the upgrade. If the card would have failed during operation, the OS would remain on a single card.
When you attempt to boot the server, do you get an error? Does ESXi display anything or do you get "no boot device found"?
The most effective use of time would to be just re-install ESXi and re-configure the management settings. If you would like to try and recover, I would boot an ESXi Installer ISO and choose to "upgrade" and see if the boot partition is still available. If not, it may have been lost/corrupted during an upgrade/when the card failed.
08-06-2018 12:14 PM
Message :
"Unable to match boot policy to currently available devices. Press enter to select from possible options.
<ok> "
08-06-2018 01:35 PM
08-07-2018 05:58 AM
Can anyone verify if this card will work in our Blades? Cisco Systems Inc UCSB-B200-M4
08-07-2018 06:04 AM
You can use the spec sheet to confirm supported PID:
