04-06-2021 07:18 AM
Hi, we currently have a chassis with 4 B200 M5 blades working, we recently acquired 4 B200 M4 blades to incorporate them into the chassis, but when inserting one of the new new B200 M4 blades that arrived, the chassis showed the following critical alert:
[FSM:FAILED]: Cap the power consumption of chassis 1(FSM:sam:dme:EquipmentChassisPowerCap). Remote-Invocation-Error: no connection to MC endpoint
Do you know how to solve this error?
04-06-2021 07:38 AM
Probably going to need a TAC case to look at logs.
Sometimes you can get alerts like this when IOMs are in a funny state, and are having troubles communicating with the CIMC.
I'm assuming you have tried reseating the new blades...
Kirk...
04-06-2021 07:43 AM
Hi Kirk
thanks for answering.
That's right, I tried putting one of the new M4 blades in slot 5 and the error appeared, then I removed it and put it in slot 6 and the error persisted
Regards.
04-06-2021 08:36 AM
How far into discovery do you get? I'm curious if there is a big mismatch between UCSM/IOM firmware and that of the CIMC and Adapter in the server...
Kirk...
04-06-2021 12:17 PM
It could be said that in the UCSM console I see the 5 blades (4 M5 working correctly and 1 M4 which is the new one that we inserted) and I see practically the Firmware versions that have the M4 blade
