Beginner
Full reset ucs
Í nerd tiverdes my ucs , Wing haver 2 Fiber interconnect .
When I finishbreset using reset configurations,  it goes directly to options where said detected peer fiber will b add to the cluster..
I need to reset and start from scratch,
See the attached file a one is after reset and other is what I want to be t start setup
Please help
1 REPLY 1
Re: Full reset ucs
Are you asking how to reset the FI config back to factory default?
#connect local-mgmt
#erase configuration
You will want to have a serial/console connection active, so you can re-enter the basic config information.
Kirk...
Content for Community-Ad
July's Community Spotlight Awards
