1828
Highlighted
Beginner
Gets Faults on 1 chassis when i config or boots a blade
I gets this faults when I associate a new blade or boots a blade in one of my UCS Chassis:
<faultInst
ack="no"
cause="thermal-problem"
changeSet=""
code="F0411"
created="2013-05-24T08:11:52"
descr="Thermal condition on chassis 3 cause:Local IOM:IOM unable to get thermal sensor reading from blades(6);Peer IOM:Thermal sensor reading not available from blades(6);"
dn="sys/chassis-3/fault-F0411"
highestSeverity="critical"
id="1127612"
lastTransition="2013-05-24T08:11:52"
lc=""
occur="1"
origSeverity="critical"
prevSeverity="critical"
rule="equipment-chassis-thermal-threshold-non-recoverable"
severity="critical"
status="created"
tags="server"
type="environmental">
</faultInst>
<faultInst
ack="no"
changeSet=""
code="F0410"
created="2013-05-24T08:12:47"
descr="Thermal condition on chassis 3 cause: Local IOM:Threshold crossing of thermal sensor reading on blades(1);Peer IOM:Thermal sensor reading not available from blades(6);"
dn="sys/chassis-3/fault-F0410"
highestSeverity="minor"
id="1127621"
lastTransition="2013-05-24T08:12:47"
lc=""
occur="1"
origSeverity="minor"
prevSeverity="minor"
rule="equipment-chassis-thermal-threshold-non-critical"
severity="minor"
status="created"
tags="server"
</faultInst>
<faultInst
ack="no"
changeSet=""
code="F0411"
descr="Thermal condition on chassis 3 cause:Local IOM:Threshold crossing of thermal sensor reading on blades(1);Peer IOM:Thermal sensor reading not available from blades(6);"
id="1127612"
lc=""
occur="1"
severity="cleared"
status="created"
tags="server"
</faultInst>
It fix it self, but I wonder if it's something I should do with it?
6 REPLIES 6
Highlighted
Enthusiast
Hi Stig,
Can you get the UCSM version / firmware on the IOM on chassis 3 and the CIMC versions for blades 1 and 6 on chassis 3?
This looks like a communication issue between the IOM and the blades on chassis 3.
./Abhinav
Highlighted
Hi.
UCSM version is 2.0.5a
IOM on Chassis is 2.0.5a
All blade in the Chassis have version 2.0.5a
Is this what you need to find out more?
Highlighted
Hi Stig,
I would recommend opening a TAC case for this and we can take a look at this in more details.
I was suspecting a bug, but that is fixed in the version you running.
./Abhinav
Highlighted
Hi.
This started after I put 3 new servers in slot 6 - 8 in this chassis.
Blade number 6 seems not to work as it should, because I can't connect to any network from this server, but the other new servers have no problems.
So I think that this server may have som issues, that causes this.
What do you think about this? Can this be the case?
/StigS
Highlighted
Stig,
I agree with Abhi, you better open a case so that we can have a deeper look at the environment and diagnose faster/better.
-Kenny
Highlighted
Hi Stig,
There can be multiple things contributing to this, once you have the TAC case we can take a more closer look at those.
Abhinav
Content for Community-Ad
