05-23-2013 11:20 PM - edited 03-01-2019 11:02 AM
I gets this faults when I associate a new blade or boots a blade in one of my UCS Chassis:
<faultInst
ack="no"
cause="thermal-problem"
changeSet=""
code="F0411"
created="2013-05-24T08:11:52"
descr="Thermal condition on chassis 3 cause:Local IOM:IOM unable to get thermal sensor reading from blades(6);Peer IOM:Thermal sensor reading not available from blades(6);"
dn="sys/chassis-3/fault-F0411"
highestSeverity="critical"
id="1127612"
lastTransition="2013-05-24T08:11:52"
lc=""
occur="1"
origSeverity="critical"
prevSeverity="critical"
rule="equipment-chassis-thermal-threshold-non-recoverable"
severity="critical"
status="created"
tags="server"
type="environmental">
</faultInst>
<faultInst
ack="no"
changeSet=""
code="F0410"
created="2013-05-24T08:12:47"
descr="Thermal condition on chassis 3 cause: Local IOM:Threshold crossing of thermal sensor reading on blades(1);Peer IOM:Thermal sensor reading not available from blades(6);"
dn="sys/chassis-3/fault-F0410"
highestSeverity="minor"
id="1127621"
lastTransition="2013-05-24T08:12:47"
lc=""
occur="1"
origSeverity="minor"
prevSeverity="minor"
rule="equipment-chassis-thermal-threshold-non-critical"
severity="minor"
status="created"
tags="server"
</faultInst>
<faultInst
ack="no"
changeSet=""
code="F0411"
descr="Thermal condition on chassis 3 cause:Local IOM:Threshold crossing of thermal sensor reading on blades(1);Peer IOM:Thermal sensor reading not available from blades(6);"
id="1127612"
lc=""
occur="1"
severity="cleared"
status="created"
tags="server"
</faultInst>
It fix it self, but I wonder if it's something I should do with it?
05-23-2013 11:28 PM
Hi Stig,
Can you get the UCSM version / firmware on the IOM on chassis 3 and the CIMC versions for blades 1 and 6 on chassis 3?
This looks like a communication issue between the IOM and the blades on chassis 3.
./Abhinav
05-24-2013 02:51 AM
Hi.
UCSM version is 2.0.5a
IOM on Chassis is 2.0.5a
All blade in the Chassis have version 2.0.5a
Is this what you need to find out more?
05-24-2013 03:47 AM
Hi Stig,
I would recommend opening a TAC case for this and we can take a look at this in more details.
I was suspecting a bug, but that is fixed in the version you running.
./Abhinav
05-24-2013 04:19 AM
Hi.
This started after I put 3 new servers in slot 6 - 8 in this chassis.
Blade number 6 seems not to work as it should, because I can't connect to any network from this server, but the other new servers have no problems.
So I think that this server may have som issues, that causes this.
What do you think about this? Can this be the case?
/StigS
05-24-2013 02:49 PM
Stig,
I agree with Abhi, you better open a case so that we can have a deeper look at the environment and diagnose faster/better.
-Kenny
05-26-2013 11:30 PM
Hi Stig,
There can be multiple things contributing to this, once you have the TAC case we can take a more closer look at those.
Abhinav
