HI all,
I am getting "SFP validation failed " error after inserting GLC-T connector in 5548 nexus switch.Is thre any seperate config required for GLC-T connector.
Ajith
Ajith,
Set the interface speed to 1000
interface ether x/y
speed 1000
Dave
Dave,
I have done speed to 1G then I am getting error " link not connected" even I have connected the nnetwork cable.
Ajith
It's GLC-T and not GLC-TX, right?
Yes it GLC-T , I have tried with 4 GLC-T connectors but all are getting same problem..
Ajith
If you have one (or more) working, swap it around.
I have done swapping with 4 connectors. This is new implementation. All four are getting same error
Are you saying that not one of your GLC-T works?
If this is so, what version is your IOS?
Yes I am getting all four same error. pls find the IOS version.
version 5.0(2)N2(1)
Switch that you use to connected with Nexus 5548 support Gigabit Ethernet ??
Why don't you test loop connect within 5548 to check port is up or not
As per datasheet nexus 5548 , switch will support GLC-T connector.
try this
unplug your GLC-T, configure/re-configure the speed to 1000. Then, insert GLC-T.
What version is the GLC-T? I had the same issue a while back and Cisco will on support GLC-T v.3
1gig capability was added to NX-OS 5.0(3)N(1)1 and later
Ajith,
Have you solve this issue now?
