08-15-2018 06:41 PM - edited 08-15-2018 09:59 PM
H
i All,
How can i verify my SD cards are OK? I think the errors im getting are related to the SD cards.
I can open a session to the UCS-E but its stuck in recovery-shell, so i upgraded to 3.2.2 which it took OK but now I get these errors:
recovery-shell# update 192.168.0.4 update_pkg-ucse-cimc.full.3.2.2.bin downloading firmware image "update_pkg-ucse-cimc.full.3.2.2.bin" from "192.168.0.4" download firmware image done, size in bytes: 40319916 installing firmware image, please wait ... activating installed image done Stage: NONE Status: SUCCESS Error: Success recovery-shell# reboot NoteRestarting system. CHIMP v1.3 Copyright Cisco Systems, Inc. (c) 2011, 2012 Attempting cisco_chimp_boot with FLAT_MMU algo Divisor: 0x00000002 Checking if we are already running from PLL Already running from PLL Image 2 validation in progress Image 2 validation COMPLETE ▒ U-Boot 1.1.4 (Oct 27 2017 - 14:04:28) U-Boot code: 87F00000 -> 87F21AB8 BSS: -> 87F26174 IRQ Stack: 87e9ff7c FIQ Stack: 87e9ef7c RAM Configuration: Bank #0: 80800000 256 MB Found SPI Chip Numonyx N28Q128 Flash: 16 MB Using default environment Net: Phy Id 61e4 not matching dev_num is 0 Phy Id ffff not matching dev_num is 1 pilot_eth0, pilot_eth1 Enable port 80 capture. Type *** to stop autoboot: 0 Reading /dev/mtd2/boot.conf...Found boot.conf version 3 Writing pid: Cisco Hardened Image Manager detected Booting Linux2 from CHIMP Running "run chimp2boot" Boot reached stage 1 ## Booting image at 008c0000 ... Boot reached stage 2 Boot reached stage 3 Image Name: 3.2(2.20171027140419) Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 7081376 Bytes = 6.8 MB Load Address: 80808000 Entry Point: 80808000 Verifying Checksum ... OK Boot reached stage 4 Boot reached stage 5 Boot reached stage 6 OK Boot reached stage 7 Boot reached stage 8 Boot reached stage 14 Boot reached stage 15 Starting kernel ... starting pid 843, tty '': '/etc/init.d/rcS' net.ipv4.tcp_tso_win_divisor = 8 net.ipv4.tcp_max_syn_backlog = 256 net.ipv4.tcp_max_tw_buckets = 256 net.ipv4.tcp_max_orphans = 8192 net.ipv4.tcp_rmem = 4096 87380 174760 net.ipv4.tcp_wmem = 4096 16384 131072 net.ipv4.tcp_mem = 12288 16384 174760 net.ipv6.conf.eth0.autoconf = 0 net.ipv6.conf.eth0.accept_ra = 0 net.ipv6.conf.eth1.autoconf = 0 net.ipv6.conf.eth1.accept_ra = 0 net.ipv6.conf.eth1_mac0.autoconf = 0 net.ipv6.conf.eth1_mac0.accept_ra = 0 net.ipv6.conf.eth1_mac1.autoconf = 0 net.ipv6.conf.eth1_mac1.accept_ra = 0 net.ipv6.conf.eth1_mac2.autoconf = 0 net.ipv6.conf.eth1_mac2.accept_ra = 0 kernel.core_pattern = /var/core/dumps/%t_%e_core.%p kernel.core_uses_pid = 1 ldconfig: /lib/libpam.so.0 is not a symbolic link modprobe: can't load module g_pilot3_nand.ko (kernel/drivers/bmc/nand_canis/g_pilot3_nand.ko): No such device or address DEVICES [SUCCESS] Updating the PCI Vendor ID. ============================================================= Readback of Current PCI DID/VID 0000000 01011137 0000004 ============================================================= Write of new PCI DID/VID ============================================================= Readback of New PCI DID/VID 0000000 01011137 0000004 ============================================================= Done watchdogkick [SUCCESS] mount: mounting /dev/mmcblk0p2 on /opt/flash failed: No such file or directory od: /dev/mmcblk0p2: No such file or directory rm: can't remove '/tmp/_flashfs.img': No such file or directory Flash image verification failed for partition2 fdisk: can't open '/dev/mmcblk0': No such file or directory Recovery mode, not starting services! starting pid 1067, tty '': '/sbin/getty -L ttyS0 9600 vt100' CISCO-IMC login: admin Password: login[1067]: root login on 'ttyS0' recovery-shell#
08-15-2018 06:54 PM
Perhaps an SD card issue?
recovery-shell# sd-card format p4
Formatting parition 4
mount: mounting /dev/mmcblk0p4 on /mnt/datastore failed: No such file or directory
09-16-2019 01:25 AM
Hi dastrix80
I'm having the same issue, did you happen to know what the fix was ?
any help or advise would be greatly appreciated..
