05-21-2013 04:25 AM - edited 03-01-2019 11:02 AM
after Upgrading the Firmware from 1.4(7c) to 1.5(1f) via HUU on my two C220M3 the speed of all fan is higher than before (8500-9000 RPM).
Is this normal?
the servers are very noisy.
best regards
Nico
Solved! Go to Solution.
05-21-2013 06:37 AM
Hello Nico,
Yes, it is normal in 1.5.1f version as we have increased the FAN speed to work around known issues.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCue68150
The next major release of firmware will accommodate additional logic that drive down the FAN speeds.
Padma
05-21-2013 06:37 AM
Hello Nico,
Padma
05-21-2013 07:28 AM
Hello Padma,
thx for ur help.
best regards
Nico
06-12-2013 10:02 AM
Hello Padma,
When can we expect this major release I have 1.5.1j? The server is still noisy and the fun speed is around 9500.
Best Regards,
Bojan
