04-03-2019 12:33 AM
I try to change via vi /etc/network/interfaces but with no luck. Now Witness vm after reboot ip shown as blank. Maybe can I just install the new one instead?
04-03-2019 03:33 AM
Greetings.
Your /etc/network/eth0.interface file should have something like:
auto eth0
iface eth0 inet static
metric 100
address x.x.x.x
netmask 255.255.255.0
gateway x.x.x.x
dns-nameservers x.x.x.x y.y.y.y
After you've saved it (Esc key, ":" "wq" sequence, then issue cat /etc/network/eth0.interface to confirm the config is still there.
Issue ifdown eth0;ifup eth0
Then ifconfig
If you are still having issues, I would check at the guestVM NIC level to make sure the virtual NIC device is not disabled or deleted.
Kirk...
04-03-2019 06:28 AM
auto eth0
metric 100
address 192.168.107.xx
gateway 192.168.107.xx
dns-nameservers 192.168.107.xx
also ifconfig eth0 up/down
and show ifconfig show ip address correctly
but login console still not show ip address after reboot
04-03-2019 08:46 PM
