How to configure UCS network with single 3850 upstream switch
ma4ctg
I have 2 FI's and a UCS chassis with 4 M200 B3 blades. I only have one 3850-48U-E switch. Is there a good document on how to connect/configure the FIs to the single switch? I know this is not ideal but until I can afford another switch I want to start using the platform.
Any suggestions?
Thanks!
mojafri
Since its not a vpc/vss configuration, you can simply have port-channel/ether-channel of UCS uplinks or single uplink (upto your requirement) directly connected to 3850. Make sure to have spanning-tree port type as edge/port-fast(in case of UCS in end-host mode) OR network (in case of UCS in switching mode).
Hope this helps !
MJ
