Hi Team,
Is there any way to enter Rack information manually of CISCO B-series blades in UCS Manager or UCS central ?
Vaibhav A.
Solved! Go to Solution.
Greetings.
There is both a 'name' and and a 'user' label in UCS Manager that can have custom values entered there.
UCS Central 'TAGs'
Kirk...
Can you please confirm what you are trying to do with screen captures or reference documentation?
Hi Wesley,
We are trying to put this information manually in UCS chassis or UCS central if possible. This is required to gather inventory information of our chassis & blades. Also this will help to find out the correct location of chassis or blades whenever we work remotely on these servers with the help of data center tech.
We also have dell chassis & blades where we have this option to put information about location of servers but unable to find the same in CISCO.
Vaibhav A.
Greetings.
UCS Central 'TAGs'
Kirk...
