03-17-2015 08:08 AM
I'm trying to get VIC adaptor on the blade and its running firmware. I have preloaded VIC adaptor details in my script which are supported for the Cisco UCS blades. For eg, (1240, 1225, 1227, M81KR, etc). So, I need to match any one from this list and get its firmware from the XML output. When I looked at the API results (dn="sys"), I'm getting only the PID's of VIC adaptors but no model name (eg. VIC 1240). My question is: how do i map the PIDs with VIC adaptor names.
<adaptorUnit model="UCSB-MLOM-40G-01"...
<mgmtController ...
<firmwareRunning childAction="deleteNonPresent" deployment="boot-loader" packageVersion="" rn="fw-boot-loader" type="adaptor" version="2.0(1.104)"/>
<firmwareRunning childAction="deleteNonPresent" deployment="system" packageVersion="2.2(3c)B" rn="fw-system" type="adaptor" version="4.0(1c)"/>
In the above output, I'm interested in getting the version="4.0(1c) by making sure the VIC adaptor name is 1240.
Karthick
03-22-2015 08:32 PM
Folks,
I'm hoping for some help here. Thanks!
03-22-2015 08:44 PM
can you not use powertools?
Get-UcsAdaptorUnit | Get-UcsMgmtController | Get-UcsFirmwareRunning
03-24-2015 12:36 AM
The tool uses UCSM XML API and we cannot deviate from that. Anyways, I have figured it out in the XML API. To get the VIC adapter models(like 1240, 1280, etc) one has to map the model or pid. Below is the list I came up with and it worked in multiple configs. The end goal is to get the name of the VIC from the API results and can be achieved by mapping below PID.
UCSB-MLOM-40G-01 | UCS 1240 Virtual Interface Card and Port Expander |
UCSB-MLOM-40G-03 | UCS 1340 Virtual Interface Card and Port Expander |
UCS-VIC-M83-8P | UCS 1380 Virtual Interface Card |
UCS-VIC-M82-8P | UCS 1280 Virtual Interface Card |
UCSB-MEZ-QLG-03 | UCS M73KR-Q Virtual Interface Card |
UCSB-MEZ-ELX-03 | M73KR-E |
N20-AC0002 | UCS M81KR Virtual Interface Card |
UCSC-PCIE-CSC-02 | UCS 1225 Virtual Interface Card |
UCSC-PCIE-C10T-02 | UCS 1225T Virtual Interface Card |
UCSC-PCIE-C40Q-02 | UCS 1285 Virtual Interface Card |
UCSC-MLOM-CSC-02 | UCS 1227 Virtual Interface Card |
UCSC-PCIE-BSFP | UCS Broadcom NetXtreme II 57712 |
04-22-2015 07:54 PM
You will need to reference the PID + Vendor + Revision in the capability catalog. In the UCSM GUI, that's how it gets the friendly details like Marketing Name, etc. There is a PowerShell Cmdlet to do that for you as well.
