12-01-2015 09:58 AM - edited 03-01-2019 12:29 PM
Hi all,
I have a planned power outage coming up in the next couple weeks where the data center will go dark for a day. I recently deployed a few UCS C240 standalone chassis in the data center and would like to find out what the best way to gracefully shutdown and powerup these chassis'.
Thanks in advance !!!
Danny
Solved! Go to Solution.
12-02-2015 11:21 AM
Danny,
If this is the case you can configure the Power Restore Polcy to "Power Off"
More info here:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/cli/config/guide/131/b_Cisco_UCS_C-Series_CLI_Configuration_Guide_131/Cisco_UCS_C-Series_CLI_Configuration_Guide_131_chapter2.html#task_7CD57F360073470DB06952F8525E828E
Wes
12-02-2015 11:25 AM
Wes got you what you need. :)
Let us know if you have more questions and/or mark the posts ans the answer(s) if this is clear now;
-Kenny
12-01-2015 12:55 PM
*power off VMs or migrate them to another Data Center
*shut down the OS
*Shut down the servers from CIMC
Let me know if you were looking for something else and I misunderstood you.
-Kenny
12-02-2015 11:13 AM
Hi Qiese and Keny !! Thanks for responding to my questions !!! Appreciate your help !!
My concern is that power might come On and Off sporadically during the maintenance window and I do not want the servers to turn on automatically when that happens.
How do I ensure that the servers do not turn on automatically when power is restored beside unplugging the power cords ?
Once the VM's are shut down, do I need to put ESXi in maintenance mode ?
I see there are different options in CIMC, can you explain the difference for each of these options ?
Power Off Server
Shut Down Server
Power Cycle Server
Thank you very much !!
Danny
12-02-2015 11:21 AM
Danny,
More info here:
Wes
12-02-2015 02:23 PM
Thank you all very much for your help !!!
Danny
12-02-2015 11:25 AM
-Kenny
12-02-2015 12:28 PM
Glad they solved it for you Danny. If you have any other questions let us know.
12-01-2015 05:00 PM
Hi Danny,
Powering down a UCS Instance:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ts/guide_old_FM/TS_GeneralTroubleshooting.html#wp1073487
However there is a more detailed version available on our forums too which can better assist in the process.
Procedure to Gracefully Shutdown and Powerup UCS System.
https://supportforums.cisco.com/document/68971/procedure-gracefully-shutdown-and-powerup-ucs-system
Qiese Dides
