Beginner
How to shutdown safely my UCS?
Hello guys
I have a CUCM 10.5 running over UCSC-C220-M3SBE and I want to know how Can I turn off my UCS in a safe mode.
I really don't know so much about UCS but I have made a little reseach and I found that I can turn off my UCS using the Cisco Integrated Management Controller (CIMC) is that correct?
If this is correct I want to know this:
1) The CICM is a separate unit of the UCS?
2) If I shutdown my server from here I still be able to access the CICM to turn it on back?
3) Is there any danger that my UCS don't turn it on back using this method?
6 REPLIES 6
VIP Advisor
Re: How to shutdown safely my UCS?
Cisco Integrated Management Controller (CIMC)  - You use this to shutdown the Server, and you can turn them back using CIMC.
This like KVM or ILO (in traditional world).
BB
*** Rate All Helpful Responses ***
Beginner
Hello
Ok thank you for your response, I know now I can shutting down and turn on the UCS using CIMC
But which option should I use to shutdown UCS. the Power Off Server Option or Shut Down Server Option? what is the diffence between them ? and I suposse in both case the CIMC will be available right?
Shutdown server will initiate a soft shutdown and Power off will be a hard shutdown.
Beginner
Thank you for clarify me the diference.
In both case after I apply Turn Off Server  or  Shutdown Server the web access to CIMC will be available?
VIP Advisor
yes CMIC available for you.
BB
Highlighted
Beginner
Hello
Everyone's tags (4)
Content for Community-Ad
August's Community Spotlight Awards
