09-25-2020 05:50 AM
I am looking at the HX Connect UI and I find very little details about the tasks being perform, for e.g. I do not see which users has logged into the HX Connect at what date/time, which user initiated the HX Maintenace for a node. Is the level of log audting configurable?
Solved! Go to Solution.
09-27-2020 06:50 AM - edited 09-27-2020 06:52 AM
Greetings.
I did a few tests including datastore expansion & deletion and didn't see event population for that.
Filed bug/enhancement CSCvv88384.
That will take a couple of days to show up at the https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv88384 location.
It would be helpful if you open a TAC case, and ask them to associate your case with CSCvv88384.
Kirk...
Greetings.
Kirk...
