10-18-2012 08:17 PM - edited 03-01-2019 10:41 AM
I have WIN2K8R2+Hyper-V Role in Cisco UCS B200M2 with NIC model M81KR
That NIC is 10GB, but when I create Legacy NIC for pxe in child vm, I only get 100MB.
The parent NIC is Cisco M81KR but why after I create Legacy nic, it shown as Intel 21140 in child vm
How to fix that
thanks
Solved! Go to Solution.
10-30-2012 03:53 AM
This is normal behavior when you choose legacy adapter for VM.
Here is information from Microsoft:
A legacy network adapter works without installing a virtual machine driver because the driver is already available on most operating systems. The legacy network adapter emulates a physical network adapter, multiport DEC 21140 10/100TX 100 MB. A legacy network adapter also supports network-based installations because it includes the ability to boot to the Pre-Boot Execution Environment (PXE). The legacy network adapter is not supported in the 64-bit edition of Windows Server 2003 or the Windows XP Professional x64 Edition.
http://technet.microsoft.com/en-us/library/cc732470%28v=ws.10%29.aspx
10-21-2012 05:51 AM
Hello Nawir,
this is not to answer your question. but just wanted to clairfy: how do you define VLANs for the M81 Adapter in Windows 2008 ?
10-21-2012 06:17 AM
MS said that is expected behaviour, nothing to do with vlan or anything.
I test in WIN2012 also only 100MB for legacy NIC
10-21-2012 06:28 AM
So how do you define multiple VLANs for your different VMs in Hyper-V ?
I think it is a driver problem. below is a screenshot from my local machine network configuration, where in there's advanced Tab to enable VLANs on the adapter:
below is a link for my original post for this issue on the community:
https://supportforums.cisco.com/thread/2178081?tstart=0
thanks,
Mohammad
10-30-2012 03:53 AM
