Hyper-V Legacy NIC
nawir
I have WIN2K8R2+Hyper-V Role in Cisco UCS B200M2 with NIC model M81KR
That NIC is 10GB, but when I create Legacy NIC for pxe in child vm, I only get 100MB.
The parent NIC is Cisco M81KR but why after I create Legacy nic, it shown as Intel 21140 in child vm
How to fix that
thanks
This is normal behavior when you choose legacy adapter for VM.
Here is information from Microsoft:
 A legacy network adapter works without installing a virtual  machine driver because the driver is already available on most operating  systems. The legacy network adapter emulates a physical network  adapter, multiport DEC 21140 10/100TX 100 MB. A legacy network adapter  also supports network-based installations because it includes the  ability to boot to the Pre-Boot Execution Environment (PXE). The legacy  network adapter is not supported in the 64-bit edition of Windows  Server 2003 or the Windows XP Professional x64 Edition.
http://technet.microsoft.com/en-us/library/cc732470%28v=ws.10%29.aspx
Hello Nawir,
this is not to answer your question. but just wanted to clairfy: how do you define VLANs for the M81 Adapter in Windows 2008 ?
MS said that is expected behaviour, nothing to do with vlan or anything.
I test in WIN2012 also only 100MB for legacy NIC
So how do you define multiple VLANs for your different VMs in Hyper-V ?
I think it is a driver problem. below is a screenshot from my local machine network configuration, where in there's advanced Tab to enable VLANs on the adapter:
below is a link for my original post for this issue on the community:
https://supportforums.cisco.com/thread/2178081?tstart=0
thanks,
Mohammad
