09-20-2020 01:05 PM
Checking BoM I saw that hx nodes Will come with esxi 6.7 pre-installed and with license.
But i dont see nothing Talking about vcenter. Do we need to buy vcenter Separarly to vmware or license its included with Hx nodes?
Solved! Go to Solution.
09-20-2020 05:59 PM
Most often Hyperflex customers purchase a vCenter license separately either through a VAR or via VMware direct.
As ESXi is shipped on the server pre-loaded, the OS must be licensed.
09-22-2020 05:52 AM - edited 09-22-2020 07:05 AM
So on Hyperflex spec sheets, the support is sold as a combined license item (correction to earlier statement I made).
The section under "VMware PAC Licenses" contains licenses and support (aka ISV1).
Those are the only items with term 'support'. All other licenses, make assumption you have support options with Vmware directly.
In general, when you purchase hyperflex system, TAC hyperflex support team will help you work through any vmware issues related to Hyperflex storage or hardware related functionality.
Some examples of non-hyperflex related issues, where you would need to have your own support contract with Vmware (or have purchased the ISV1 type contracts with Cisco):
Not a complete list, but wanted to give you the general idea.
Kirk...
09-20-2020 05:59 PM
09-21-2020 03:46 AM
VMware vCenter License should be bought separately. However, ESXi licenses and support can be purchased from Cisco. This allows to get hypervisor and Hyperflex support from Cisco itself.
09-21-2020 04:19 AM - edited 09-21-2020 04:20 AM
That is a good point.
As a reminder, VMware 'licenses' are 'right to use'. and do not include support. Support is additional different line item, and will have "ISV1" in title when purchasing Vmware support through Cisco.
Kirk...
09-22-2020 04:26 AM
Hi ,
Thanks. So HX-VSP-EPL-D part number only have vshpere licenses not support ? Do you know part number for VMWare support?
Kirk...
