04-07-2011 05:25 AM - edited 03-01-2019 09:52 AM
Hi All,
I have a problem with how to clear CIMC password of the C250 M1 server. I had check the installation guide and I did not find the method.
I just got a server from the customer side, and I want to check the operation status of the hardward. We can use the short jumper in the C200/C210 server to clear this, but I did not see the similar method for CIMC. If anyone can help on this?
04-07-2011 05:29 AM
You will need to hook a monitor and keyboard to the server to reset the CIMC password.
Reboot the server and you should see a message on the screen to press "f8" to enter the CIMC setup. From there you can reset the CIMC password.
louis
04-07-2011 05:36 AM
Hi Louis,
Thanks for your reply. I saw it from the KVM console.
I had reset the CIMC to factory default configuration.
Thanks very much!
