04-26-2018 08:57 AM - edited 03-01-2019 01:31 PM
I am trying to create a discovery profile in IMC Supervisor 2.2.0.0 based on a IP Address CSV file.
I downloaded the sample file and use that in conjunction with this support doc to create my file.
Trying to import it I am getting the error: Invalid Tags format for 192.168.0.41. The correct format is :;:.
The support document indicates that for any fields you dont want to include just leave them blank. My CSV looks like this:
192.168.0.41,Maryland Primary,"Baltimore, MD",Steve Schmitt, Maryland Primary,,
I'm at a loss. What am I doing wrong? Does anyone have an example of a completed CSV file they can share? Thanks!
Andrew
Solved! Go to Solution.
04-27-2018 08:26 AM - edited 04-27-2018 10:29 AM
Greetings.
Looks like the comma in your location field is being parsed as a CSV field separator, which makes it look like your Maryland primary value is actually in the TAG field, which would then not be correctly formatted for a TAG.
Try pulling the comma out, and I bet it works fine.
192.168.0.41,Maryland Primary,"Baltimore MD",Steve Schmitt, Maryland Primary,,
It appears that the CSV import does not escape out the comma in the field that is enclosed with double quotes.
I filed bug CSCvj22809 in your honor ;)
Kirk...
Greetings.
Kirk...
04-30-2018 11:42 AM
