06-22-2016 12:32 AM - edited 03-01-2019 12:47 PM
Hi all,
we deployed the Cisco IMC Supervisor for VMware yesterday. So far so good - everthing is up and running. Afterwards i added 2 C220 M4 Rackserver, the connection Status is success, but the Connection Message says -- Connection Failed: Version 2.0(10b) is not supported. Only versions above 1.5(4) for C-Series are supported.
Until yesterday i always thought 2.0 is higher then 1.5 :)
Does anyone have or had the same issue?
Alex
Solved! Go to Solution.
06-22-2016 05:02 AM
Hmm, you are right, the bug shouldn't reference an article that is not public facing yet.
You'll probably need to open a tac case (please reference the https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz24466 bug), and they should be able to hook you up with an updated .xml file, along with instructions.
Since the article hasn't been flagged as public facing yet, I can't just drop the contents out here.
Kirk...
06-22-2016 03:56 AM
Hi Alex
This are standalone servers; if you check
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
you see that you are 100% correct !
http://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/datasheet-c78-733571.html
The IMC Supervisor supports the following platforms:
● Cisco UCS C-Series Rack Servers: Firmware Release 1.5(4) or later
◦ Cisco UCS C220 M3
◦ Cisco UCS C240 M3
◦ Cisco UCS C220 M4
◦ Cisco UCS C240 M4
◦ Cisco UCS C460 M4
◦ Cisco UCS C22 M3
◦ Cisco UCS C24 M3
◦ Cisco UCS C420 M3
◦ Cisco UCS C3160
Walter.
06-22-2016 04:28 AM
Hi Walter,
nice to here from you again - how are you? We last met here at Fritz Egger GmbH about 7 years ago :)
I still don't unterstand the error message. Version 2.0(10b) is later than 1.5(4)?!
There isn't even a download option for the 1.5 Release..
https://software.cisco.com/download/release.html?mdfid=286281345&softwareid=283850974&os=&release=2.0(9l)&relind=AVAILABLE&rellifecycle=&reltype=latest&i=!pp
Cheers,
Alex
06-22-2016 04:37 AM
Greetings.
Obviously 2.0(10) is higher than 1.5 :)
Please see https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz24466
Conditions:
This happens whenever the firmware versions have a double digit for its maintenance version
Workaround:
Manually edit the validation file via the shelladmin. Follow the techzone article for the same:
https://techzone.cisco.com/t5/IMC-Supervisor/Can-t-import-C240-M4-with-firmware-version-2-0-10b-not-supported/ta-p/924696
A future update to IMC supervisor will resolve this.
Kirk...
06-22-2016 04:46 AM
Hi Kirk,
ah, thats nice - so i don't have to worry about my mathematics knowledge :)
There is only one problem - i can't open the techzone page.
Tech Zone is a restricted community that requires Cisco credentials to access.
Best regards,
Alex
06-22-2016 05:02 AM
Kirk...
04-01-2019 05:19 PM
