Impossible to access to IMC Web Interface
MaximeVilain
Hi everyone,
I'm encountering issues to access to an IMC on a Cisco UCS C240 M3 Rack Server.
The card itself didn't get any updates in a while and is currently running version 1.5(4) firmware.
My question is the following : Is there any means to connect to it's Web Interface now that Flash Player's dead ?
I saw that there are some newer versions of the firmware but I couldn't find any informations about if those newer versions still require Flash Player to connect to it.
Thanks for the replies !
Maxime
Good afternoon, Maxime.
Sorry, bad news from Cisco. I have attached the notification PDF, you can find the same information in the UCS C-Series release notes, here is the link to the 3_0_3 release notes. Please read on Page 1 of the document.
LINK: https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/b_UCS_C-Series_Release_Notes_3_0_3.pdf
KR,
Nick
NickAdair90442
Good Morning, Maxime.
You have a few options.
1. Use the Cisco HUU-NI (Host Update Utility - Non-Interactive)
* Requires CIMC 1.5 for non-interactive update
LINK to Video: https://community.cisco.com/t5/unified-computing-system/cisco-standalone-c-series-huu-utilities/ta-p/3638543
1. Use the KVM cable and update it manually. Be sure and have the required files on a USB drive connected to the KVM. See the LINK for option 3 to understand the procedure to extract the needed files.
2. Use CLI to manually update firmware via SSH
* You still need the files on a USB, follow the LINK below to understand the procedure before starting.
LINK to Cisco CLI Configuration Guide: https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/cli/config/guide/3_0/b_Cisco_UCS_C-Series_CLI_Configuration_Guide_31/b_Cisco_UCS_C-Series_CLI_Configuration_Guide_40_chapter_01110.html
I hope this helps.
KR,
Nick
Hello Nick,
Thanks for your quick reply.
Do you know if updating the IMC's firmware will allow me to acces the Web Interface without needing Flash Player ?
KR,
Maxime.
KR,
Nick
Hello Nick,
Once again, thanks a lot for your help !
I'm going to test the solutions you gave me and those in the release note, hope it's going to help me.
Anyway, have a nice day !
KR,
Maxime.
