08-19-2011 01:21 AM - edited 03-01-2019 10:01 AM
Hi All,
I'm beginner with UCS and had received my loan unit yesterday. I've connected all the cables and have two question:
1. My loan unit come with a Catalyst 3750X with expansion module of 10GE (C3KX-NM-10GE). I've configure the port 5 in both FI and the Catalyst TE port as trunk but UCSM detected it down (noconnect). Do I have to create a service profile first before the link went up?
2. We dont have any MDS and plan to directly connect the Netapp storage using the uplink FC port. Can we still use the VSAN features? (as per understanding the far-end port device must has NPIV support like MDS switch)
Thanks!
Rgds,
Nazri
08-19-2011 04:25 AM
On the UCS Fabric Interconnect (FI) make sure the port is confiugred as an uplink port not a server port. Make sure you created all the vlans on both the 3750 and the FI. Since you have just a single port do not try to use port-channels. Other than that its a connectivity problem so troubleshoot it as you normally would. Try isolating the issue to the FI or the 3750.
You can't use VSANs if you are going to directly connect the netapp to the FI. I'm pretty sure the Netapp does not understand VSAN tagging. You'll need an MDS or N5K if you want something more complex.
08-19-2011 06:39 AM
For Ethernet Port Channels you also need to use LACP, active on upstream switch(3750)
