Field Notice 70545
353
Markus5849
Beginner
Is FET-40G transceiver supported in FI-64108?
I've checked the FI 64108/6400 spec sheet but I can't see FET-40G transceiver on the list of supported transceiver. I can see other 40G QSfP but not FET-40G. May I know if this FET-40G is supported on FI 64108?
1 ACCEPTED SOLUTION
The 2304 is not supported with the 6400. You would want to get a 2204 or 2208 for 10G connectivity or 2408 for 25G connectivity to your 64108.
3 REPLIES 3
Wes Austin
Compatible/supported SFP can be found here:
https://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/6400-specsheet.pdf
It does not look like the FET-40G is supported.
In that case, can I use break out cable to connect my FI with the IO module? I have hardware as below:
Fabric interconnect: FI-64108
IO Module: UCS-IOM-2304V2
Think of using MPO cable break out to 4x10G LC and connect to fabric interconnect, will this work?
Create
Recognize Your Peers
Content for Community-Ad
