job status clarification
i am new to tidal and any input's on below clariifcations
1)what is meant by Deferred status for a job in Tidal and when a job will go to this status with an example?
2)Let us say job A is schedually on daily basis.If Job A is aborted(completed abnormally) on previous day.whether Job A will run on next day?Do i need to change the status to JOb A in previous run to completed normally to make it runnable on tommarow?
3)IF job is aborted(completed abnormally) in tidal when we will change the status to (completed normally) manually?
Keny Perez
Level 8
Level 8
I think you got this posted in the wrong community/section of the community... this section of the community is for Data Center products, like UCS and whatever you install in them and their support on UCS (pretty much)
What is Tidal? maybe I can help you find the right place to post your question.
-Kenny
Keny,
I suspect that you are right.
This post seems to be for Cisco Tidal Enterprise Scheduler.
http://www.cisco.com/c/en/us/products/analytics-automation-software/tidal-enterprise-scheduler/index.html
