Jumbo Frames and DF bit
Walter Dey
Enabling Jumbo Frames on UCS doesn't seem to set the DF bit ? correct ?
Can this be set by UCSM and/or CLI ?
Once I did the test about the jumbo frames network performance and can't see any significant difference.
In that time I used a oracle RAC installed in the UCS and a NetApp Filer with DNFS configuration.
In the UCS you must configure MTU in two different places (QoS configuration and vNIC configuration).
In your test with df-bit flag enabled use the packet size maximum of 8972.
richbarb
Hello Wdey,
Enabling jumbo frames doesn't touch in the df-bit.
To enable JUMBO in the UCS, you can follow this great guide created by Peter Revil.
http://www.ccierants.com/2013/10/ccie-dc-definitive-jumbo-frames.html
There is a specific section to enable jumbo on UCS.
Thanks for this pointer
UCS customer uses Jumbo frames for NFS, connecting to a Netapp Filer which is in a different IP subnet.
He compared performance with standard Ethernet frame size and Jumbo frames, and didn't see any difference.
I therefore proposed to do a test from ESXi
vmkping -I vmk2 -d -s 9000 192.168.......
vmkping -I vmk2 -d -s 1500 192.168.......
which fails, however
vmkping -I vmk2 -s 9000 192.168.......
vmkping -I vmk2 -s 1500 192.168.......
works ok
Therefore, somewhere in the network between UCS and Netapp, there must be a problem.
It seems, that typical OS (e.g. ESXi) don't set the DF flag.
8970 was the solution ! Thanks Richard !
