05-26-2015 10:33 AM - edited 03-01-2019 12:12 PM
Running CIMC 2.0.3i, KVM is giving the error, network connection reset. CIMC 1.5 seemed to work fine.
Seeing the following errors in Java console:
05-28-2015 09:42 AM
What is the current Java version in use?
Does this happen on different PCs?
-Kenny
09-01-2015 11:09 PM
I am having java version 8 update 51.
It is working in other pc's not in mine. what could be the problem?
Babu
09-02-2015 05:16 AM
Can you tell me your system configuration CIMC release notes are different for different PC's, I need to check if your system requirements meet the release notes specs.
09-02-2015 06:06 AM
Hi Farhan,
when you say system configuration, are you talking about OS and java version?
-Babu
09-02-2015 09:42 AM
Yes, I am talking about both. Please see the document below in the link to help you upgrade firmware:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/cli/config/guide/1-4-1/b_Cisco_UCS_C-Series_CLI_Configuration_Guide_141/b_Cisco_UCS_C-Series_CLI_Configuration_Guide_141_chapter_01101.html
There is other link below for CIMC relase notes so you can check if the firmware version is compatible with OS you are using or not:-
Also, check the release notes below for compatibility:-
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/OL-28995-01.html
If this doesn't solve your problem, open tac case, www.cisco.com/tac
