10-11-2018 04:31 AM
we are using KVM IP Pools in UCS Manager 4. We have one IP for every Blade in the UCS. Is there any way to reduce the number of IPs in the pool and assign them like DHCP with a short lease?
thanks,
Andreas
10-11-2018 07:24 AM
Hi Andreas,
There is no dhcp lease option for kvm ip pool. Hopefully you are using just one IP for each servers, as by default server will use ext-mgmt-pool to pick the ip. And another if you are using service-profile.
Please rate if you find it helpful.
MJ
10-11-2018 07:31 AM
10-11-2018 07:44 AM
You will see that option enabled when UCSM is connected to UCS Central. We have global & local both.
